01-29-2005, 07:29 PM
NH
I have just been through this with my wifes car. I was losing power at a connection above the drivers feet to the module. It needs power to the module for it to work which it sounds like it might be losing. If the motor runs when you hot wire the orange and yellow wires (you can do this at the motor or at the module) then keep swimming upstream till you find it. I have a spare switch and control module if you want to try them. The Explorer forum is a useful site also. Well it's a lot more useful than the generic circuit diagrams in the book and nowhere near as good as the Alldata info you're getting. It sounds like you're close with the relay you first had see if those wires match the terminal 7 and 8 at the module and are getting power. Good hunting.
