Old 02-05-2005, 04:01 AM
rbray rbray is offline
Default E-M Understeer questions
Hi Guys,
I have an EM with an 8.8 rear and the custom tubular front end.
I'm running a 351W and adjustable coil overs.
The car has not been to the alignment shop yet, but I'm trying to get in the ballpark before I start shelling out money.
Right now I have the toe-in adjusted to what I think is close to zero. The camber is set by using shims, so it is currently set to whatever the factory shims offer.
The car tracks straight as an arrow, now wheel shake, but it does understeer. I notice the understeer at times on the street, but on an autox course the car just plows like a pig even after using all the weight transfer techniques.
I'm wondering if I should try adding some toe-in by adjusting the tie rod ends.
What do you think?
Roger
