Old 02-05-2005, 05:14 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
289's, and then 302's up to about the '85 model year used 28 in/oz external balance on the rotating assembly. Then, Ford, in its infinite wisdom, changed the the external balance to 50 in/oz. But only on the 302/5.0 motors.
351W's have always used the 28 in/oz external balance throughout its production life.
Flywheels (157 tooth) and bellhousings are interchangable between 302/5.0, and 351W's. Later motors, and FMS flywheels use 10 1/2" clutch.
Not absolutely certain on this, but the 164 tooth flywheel (actually the flexplate) were used on full size cars and trucks depending on the trans used.
Used the 28 in/oz FMS billet flywheel, FMS billet SFI front balancer, Centerforce street performance clutch.
Everything works fine, and pedal effort is normal.
