Old 02-07-2005, 04:43 PM
G.R.'s Avatar
G.R. G.R. is offline
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Coach it sounds as if the fan relay may have gone bad. Or the ground for the relay is loose(not likely but possible). I encountered a similar problem with my fan/relay while working out some other electrical gremlins, turned out the relay chose that time to go belly up also, the fan ran continuously. Put a new relay in and see if that works. After trying to figure out what the heck was wrong I put in a new relay(painless had enclosed 2 in the fan kit I ordered, by mistake I'm sure) worked great after that.
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
