Old 02-09-2005, 01:05 PM
stuck's Avatar
stuck stuck is offline
Cobra Make, Engine: FFR3200, Carbed 351W, IRS, TKO600 RR
I looke dinto it as well, the fms billet flywheel has both 8mm and 5/16th. If you are using a diaphram style clutch, they line up with the 8mm, if you are using the 3 arm type, they line up with the 5/16....
But after asking aound, it seems pretty common for them to strip out regardless...
Ryan Logan
FFR3200 Comp - NASA #27 (ST-1)
TCC President '03
www.cuttingedgeracing.com
