Old 02-10-2005, 04:28 PM
S_Beaudry's Avatar
S_Beaudry S_Beaudry is offline
Cobra Make, Engine: (building) - Hunter #74 w/ 302 small block (320hp under the hood). . . how many wires are there in a wiring harness?
Send a message via AIM to S_Beaudry
Default 302ci bolt sizes needed...please help
Need some sizes for bolts needed to finish up the 302ci, please help if you know......
bolts to hold crank pulley on?
bolts to hold water pump pulley on?
bolts for the mechanical fuel pump (2 bolts)?
bolts for the motor mounts in the block (2 on each side)?
bolts for the flywheel, are they 7/16" x 20 x 1" ?
bolts to hold oil pump in (2 bolts)?
Anyone who can help, please help.....
I'm not busy because I did it right the third time . . .I think!
