  #30 (permalink)
Old 02-12-2005, 08:58 PM
Dominik's Avatar
Dominik Dominik is offline
HI!
here is a new pic.
for those who don't know the orig setup it may help a bit.
the upper control arm UCA is mounted at an angle of about 3 deg.
so the uprights movesbackwards in bump giving more castor.
the trailing arm is mounted with a down facing bracket to the LCA, to allow for movement.
the 12,... deg of the LCA mount chassis side is probably no critical, just to push the bolt in.
I used a heim joint for the LCA at the chassis to allow for the CCW turning of the LCA in bump (a rubber bush would do as well).
I shall check toe change and castor / camber curve. Now is the time!
Dominik
If I don't respond anymore, that's because I can't log in
