Thread: Tremec question
Old 02-13-2005, 08:01 AM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Mike:
Just as a for instance my setup is as follows:
Tremec TKO 600 w/ 0.82 fifth
3.07 final drive ratio
11X17 Wheels w/315X35X17 tires
Engine is a 428 opened up to 450 cu. in and putting out somewhere around 450 hp.
I spend a long time with the gear calculators trying different combinations until I arrived at the above.
The car is/was intended to be a street driver from the start Power wise, if I simply snap the throttle open in either 1st or 2nd it will break the rear wheels loose but it's a very tractable setup on the street as long as I don't get rambunctious. Highway cruise at 70 gives me about 2300 rpm and I hear more wind noise than exhaust.
All of the components inter-relate with eachother in figuring out your final setup.
Take some time and consider the final combination before you commit to it. Sometimes the morning after will bring some considerations into light that you hadn't considered the night before. DonC
