Old 02-16-2005, 01:07 PM
HSSS427's Avatar
HSSS427 HSSS427 is offline
Cobra Make, Engine: ERA #414 427 s/o w. Shelby Aluminum heads, Edelbrock Performer RPM Intake, Mighty Demon 750, Tremec TKO 600
Default I'm doing this real time.....
Got the laptop here on the bench, so will take ya'lls advice as follows:
1 - Remove the 50cc pump and go back to 30cc with no gap between the pump arm and acctuator screw head. Pink cams on both primary and secondary
2 - This then keeps me from needing a spacer. However I have a 1/2" phenolic 4 hole spacer on the way from Summit. Should I still use it regardless?
3 - Change the primary jets to #70 - up from #68
4 - Change secondary jets to #73 - down from #80
5 - Initial adjustment on the idle screws as Frank indicated
6 - The ProForm body has the removable air bleeds so any further info on what I might try there is appreciated
Will post results as I get them. Hopefully the next one is that the car will run!
Thanks!
Scott
