Old 02-16-2005, 05:44 PM
zipzip's Avatar
zipzip zipzip is offline
Cobra Make, Engine: Midstates work in progress, personally built 302
Roscoe, you're right on...
Loctite makes a whole series of gasketing compound. The one I think is most popular is 515. It's anaerobic, which means you don't get hardened globs inside the trans like silicone will do.
You can probably pick some up at a local bearing supply house or online. You can also do some research at www.loctite.com
The permatex should have sealed it though... you sure all bolts are tight and the faces were flat with no burrs, nicks, etc?
You might be a redneck if you think the National Anthem ends with "...Gentlemen, start your engines."
