Old 02-16-2005, 08:10 PM
HSSS427's Avatar
HSSS427 HSSS427 is offline
Cobra Make, Engine: ERA #414 427 s/o w. Shelby Aluminum heads, Edelbrock Performer RPM Intake, Mighty Demon 750, Tremec TKO 600
Default More stuff.....
I checked the air bleeds and found the following: Idle bleeds are #75 on primary and secondary. Main circuit are #36 all around. Also the power valve on the primary side is 6.5, and there is no PV on the secondary plate - it has a plug in it so trying to determine if I should install a PV on that side as well. Also need to check the vacum level and float levels as I didn't have a chance to do that either.
Thanks!
