Thread: Wheel hop
Old 02-17-2005, 06:18 PM
Dennis Kelley Dennis Kelley is offline
Cobra Make, Engine: BDR 302 AFR 165
I'm no expert but what is the ride height in the rear? Wheel hop is usually associated with flex. Check and make sure that all the rear suspension bolts are tight. If the ride height is normal I would say that there is something loose. Has it just started the wheel hop? I'd do a bolt check. There are two bolts on the back of the differential and one on the front (19mm I think) I would start there.
Good luck
