Old 02-19-2005, 06:25 PM
zipzip's Avatar
zipzip zipzip is offline
Cobra Make, Engine: Midstates work in progress, personally built 302
We use "Trans Prep" at work (the company I work at makes industrial gearboxes).
It's made by Life Automotive Products Inc, Memphis, TN. It's about the consistency of grease but WILL thouroughly dissolve at temperature. Good idea with the Vaseline though...
BTW: you can also mix the trans prep with oil to make it thinner for putting on seals, etc. as a pre-lube.
You might be a redneck if you think the National Anthem ends with "...Gentlemen, start your engines."
