Old 02-21-2005, 02:42 PM
JAM1775 JAM1775 is offline
Cobra Make, Engine: SPF 974
I am thinking of a $38 Dynomax muffler. They are in Jegs , item # 289-24219 Dynomax Bullet mufflers with 3" inner tube. The inlet is also 3" but I figure that could be cut at the weld and attached to my 3.5" pipe at the muffler's tapered inlet. The exhaust tip is also 3" but that is not problem as that it is only 2.5" , can be cut or slip right inside my existing baloney tip extension. I'd gain from 2.25 to 3" inner tubes. Do you think the Dynomax mufflers will do the trick ?
