  #50 (permalink)
Old 02-22-2005, 04:27 AM
misfit41 misfit41 is offline
Cobra Make, Engine: CSX4761, KCR Shelby Alloy 496,760hp
Send a message via AIM to misfit41
Originally posted by Robert Evans
Bill,
Regarding cutting and installing...You would normally start at the front of the garage with the trim edges and work toward the back of the garage. Cutting is done with ordinary wood-working tools. I like a table-saw with a combination blade best, but a jigsaw works well also.
Rick,
RaceDeck meets all Gov't standards for slip-resistance. The tread on top of the Diamond tile is about 20 thousandths tall, so it does offer some type of slip control. It is a happy medium between easy cleaning and anti-slip. If RaceDeck feels slippery to you, then an epoxy floor will be like an ice-rink.
Y-Not,
The support structure on the bottom of the tiles are one inch on center, so unless you have a very high concentration of weight in less than 1 sq. inch, it's no problem. I have a big Snap-On tool box and it rolls across with no problem at all. The Circle-Trac tiles work especially well with casters.
Robert,,
Did I understand correctly that the tiles are over 1" thick ? That would be an issue for me since I wouldnt want to have lips at door openings.I also have some finished flooring and a bathroom with hardwood and the added height would make water tend to puddle in the lower areas.Did i understand correctly ?
thanks,Tim
Tk
"this whole Adult thing just isnt working for me "
