Old 02-23-2005, 02:01 AM
TJBERT67's Avatar
TJBERT67 TJBERT67 is offline
Default Spf Coolant Reservoir Question
HELP!! Engine install is complete, but I noticed there is a hole on the top of the coolant reservoir canister. The hole is BELOW the hose on top of the canister i believe would be used to allow excess colant to escape to the ground. I am not referring to the puke tank, but the reservoir canister located in the lower passengerside front of engine compartment that the puke tank hose is connected too. It looks like coolant would piss out of that hole before it could ever reach the overflow hose on the top of the canister. I am sure this is a dumb question but i need a little help from some of you experianced spf owners. thank you in advance Tom
P.S. It appears that the hole is machined into the canister as it is perfectly round and does not look like it was not intended to be there. the hole is roughly the size of a round toothpick diameter.
