Old 02-25-2005, 05:58 PM
Zoom This's Avatar
Zoom This Zoom This is offline
I use an MSD 6AL with no problems on my 418 stroker. Yes, the Stellings air cleaner will do you motor no favors for HP. Get a K&N 2x9" air cleaner if you want something that is close to an original look but with a premium air filter element. The A/F ratio is too rich as far as I can see. Your ratio should dip to 11:1 or so when you nail it, but come back up to around 12.5:1 or 13:1 at high speed WOT. The MSD systems are extremely popular as an aftermarket system. I would replace the module before I installed a completely new system. Make sure everything is wired correctly.
My HP curve on the dyno is very linear and climbs picture perfect. On my motor design the torque is at its peak at 3000 rpm and stays relatively flat across to 6000 rpm where it drops off about 50 lbs. Good luck on your motor and dyno pulls.
