Old 02-27-2005, 05:47 AM
whitey94 Whitey you should be able to run 5.5 psi to that carb and not have the float being knocked off the seat. I would replace the float and seat. Are you sure that there is not some small piece of crap caught in the sealing area? I would call Good old Vic and ask him if he stands behind his name? Explain the problem and see what he can do to fix the problem. You should have your fuel pump turn on for 3-5 second than go off. This will fill the bowls in your carb. Get an pressure switch to a relay to turn the pump back on when oil pressure is passed 10psi. I would try the needle and seat first. 4.5 psi is nothing for fuel pressure. If Vic doesn't help, Look at a proform,barry grant, demon or one of the others, even a holley 600 dual feed dual pump. Save the carb and go to one of the NHRA races and show them what a wonderful carb they make and the problems they are having. This always helps sales . Try the nice way first. E-mail back if the seat and float don't fix it. I would recomend a carb heat shield between the carb and the manifold. Wrap the fuel lines in insulated covers to keep the fuel cooler. When the engine is hot and you turn off the motor, do you lift the hood to help get the heat out of the motor area. Add a 1/2" spacer between the carb and manifold this will also help with the heat not transfering to the carb. Good luck Rick Lake
