Old 02-27-2005, 06:27 AM
casaleenie casaleenie is offline
Cobra Make, Engine: Unique 289FIA / SA 351W / a truly glorious machine
Default You think it is Casaleenie, but.....
......... it's not! Rdorman signing in here as Casaleenie (oh the damage I could do! )
Not enough information to make a recommendation. Demon has a spec sheet that you can fill out and they will recommend a carb. Hard to go wrong.
Ford testing back in the early seventies showed a 20 HP increase just from switching from a 750'ish carb to a 830 carb on a stock high performance Cleveland. So to much? Probably not. Would you want to live with a 830 for a driver? Probably not. Basically, you need to provide a LOT more information for any one to make a good recomendation.
Rick
