Old 02-27-2005, 11:42 AM
GeeDoubleYouSee GeeDoubleYouSee is offline
Cobra Make, Engine: Superformance 351W
Speedometer
The problem of odometer is solved, now I just checked my odometer for accuracy and the results are not good. The test I performed was a 20 mile test, in which case i got a 30 mile reading. The gear that drives the odometer is not at fault, I think my trans gear is the problem. I have a 19 tooth gear on the trans side, Does anyone know what gear should be used with a tremec 3550 and 3.73:1 ratio differential??? Has anyone with a superformance cobra checked thier milage "real time"?
Thanks
GWC
