Old 02-28-2005, 05:12 AM
DAVID GAGNARD's Avatar
Scott;
Thanks,that's exactly what I was looking for,this should do the job very nicely.........
One more question,as I have never run an oil cooler,what size lines do you recommend,10AN or 12AN?????????
331 cu in,9quart road racing oil pan,13to1 compression race only motor,the oil pump is a Melling stock volume pump,but modified for racing with an adjustable pressure relief,right now set at approx. 65 psi at speed and should have about 35 or so psi at idle,in a 65 Mustang road race car............solid roller cam with oil restrictors,this motor probably will not see more than 7000rpms.........races usually last anywhere from 20 to 30 minutes with the occasional 1 hour Enduro..........
Thanks;
David
DAVID GAGNARD
