Old 02-28-2005, 07:18 AM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
David,
What are the fitting sizes in the rad.? If you are talking about #6 fittings or so the the pressure drop across internal Radiator cooler will be high. This P drop will be too high and defeat the #12 feed= return line size. Adding 220 to 240 degree oil to an already taxed coolant system may not help on a race toy. They do it on factory cars but have all engineering paramiters to design a give and take system.
Adding a DPDT SW = double pole double throw switch with 2 sensors lets you read 2 points but temp at engine is more useful.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
