Old 02-28-2005, 09:48 AM
coyled coyled is offline
David, I have had a hi-tech for a number of years. I would run a 600 pound front spring with the current sway bar you are running. I would start with 500 pound rear springs. If it pushes too much, go to 600 pound rear springs. I ran the 600 front, 500 rear for a while, it worked well. Stay way from a rear bar as it can cause the inside tire to unload at the exit, just when you need traction. Good luck, Scott.
