Old 02-28-2005, 01:12 PM
mloy mloy is offline
Cobra Make, Engine: 289 Leaf Spring - On Hold
Are the 427 lower arms the same dimensions as the 289's? I know the shock mount is different. What is the dimension from the centerline of the bushings to the center of the balljoint on the 427? Only reason I ask is because I can supply the 289 front lower arm drawings. Also, the 289 uses 1 1/8" tubing for the arms, what does the 427 use?
Mick, any chance you could scan the body tubing drawing and send it?
Thanks,
--Mark
