Old 03-02-2005, 11:17 AM
BB427 BB427 is offline
Cobra Make, Engine: 427SC Unique
Check the float levels. If the floats are high in an IDA everything goes super rich at idle.
Also, did you add air filters to the carbs? They also mess things up prett quick.
Do you have an exhaust leak? IR intakes and carbs do not like exhaust leaks. Will cause popping through the exhaust.
Good luck
BRent
