Old 03-06-2005, 11:13 AM
AlphaCobra AlphaCobra is offline
Cobra Make, Engine: Shell Valley, Southern Automotive 351C, Toploader
Default Clearance Part Deux
For those of you with 3" - 4" clearance, did you attempt to raise the low point of the under carriage? For instance, the bolt holes around the scatter shield could provide you an extra inch or inch and a half of clearance if you were to cut it off. The tips about avoiding pot holes and hitting driveways or speed breakers at a 45 degree angle will be used no matter what clearance I have. Did not know if any of you had additional concerns.
Shell Valley Cobra
Southern Auto 351C / 4 sp Toploader
Jodeco Auto Paint (Bruce B)
