Old 03-07-2005, 03:33 PM
rdorman Rick reassembly the hub assembly and check the play of he hub assembly. You will need a magnetic of visegrip to measure the play in the bearings. How loose is the number? Pull apart the axle end and measure the spacer. Add the play number to the spacer number and this is the new spacer you need. ERA has the list for the jag numbers for the spacer. I would add .002 pass the magic number and only tighten the axle nut to 120lbs. Then look for the hole in the axle to put the clotter pin through. I know jag puts alot of load on the bearings to hold everything in tolerance. If you have trouble, call me I will talk you through it. Rick Lake 732-254-3536. Where's Chaplin, Hope he is working
