Hey Kyle
I just finished a 347 for my 66 GT350. I used CHP kit. I belive they called it the Pro kit. I paid 1299.00 at the time for the kit. If you do not have a block, look into getting one from the same company and hopefully save money on block prep.(clearancing for stroker) and balancing the rotating assembly. Machine work aint cheap and you have to check the work they do anyway no matter who does it.
I used AFR 185 heads w/ roller rockers. I took a step backwards on efficiency and power when I relaced the brand new roller cam bearings in my new Ford R302 block w/ standard bearings for a solid lifter cam and lifters. I wanted it to SOUND and LOOK stock under the hood, and it does. I have no dyno results except for computer generated estamates peak of 464 lbs. torque @ 5500. Take your time deciding on how your going to drive your car before you pick a camshaft. The same estamates my torque at 365 @ 2500. Thats good bottom end (early) numbers and I get more of a rush from that than shifting at 7200. I love it. -Gary
