Old 03-09-2005, 07:42 PM
tpiini tpiini is offline
Originally posted by Big-Foot
It's usually a clutch adjustment that needs to be made when a Tremec or T5 are involved.
The Technique is also to be considered. If you shift from Neutral into a forward gear and them quickly shift from the forward gear into reverse, it will stop the rotating mass inside the transmission and allow a shift into reverse with minimal grinding of gears.
Absolutely check the clutch engagement. I went through months of hell trying to diagnose a shifting problem with my 3550. After disassembling the transmission and finding nothing wrong with it I went to the clutch. That had been my problem all along.
