Old 03-10-2005, 09:44 AM
blykins blykins is offline
Your head gasket thickness will affect your compression ratio. Have you had the engine built yet? I used ROL graphite head gaskets. I heard they were great for street engines. If I remember correctly, they have a 4.100" hole and they're .041" thick. You can get thicker ones or thinner ones depending on if you need to fudge your CR a little.
Distributor? MSD.
I would think one fuel pump would be plenty if you pick the right one. Get the one with the pressure and volume you need. Shouldn't need anything more.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
