Old 03-11-2005, 04:37 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
Well, sort of. I ran a screw down water pump belt so if the alternator belt got tossed ( high RPMs ) the water pump would stay in tack. You can run the three as you asked, it is a prefered way.
If you are running PS, may I suggest a pump that cuts out at 1500 RPM or can be shut off with a switch or something. PS in a cobra may make the steering too touchy and lead to too sensitive a wheel. The ideal would be to have PS when you need it and manual the rest of the time. PS is best for parking lots and slow steering apps.
Going to serpentine could be pricey. I suggest you call March and ask them for the entire package on this one.
Hope this helps.
