Old 03-11-2005, 07:20 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
Temp sending unit for Emmissions. Or, thermal switch for vacuum line routing. Or, cold air lever activation switch for cold startup. Or, heater hose connection. Or, HVAC temp switch for blend.
Got any of these??? Hey, it's a spot you can detect, bleed or measure the coolent before the T'Stat. If you do not want to use it, plug it.
hope this helps.
