Old 03-11-2005, 09:06 AM
sirelesar sirelesar is offline
Cobra Make, Engine: B&BEFI 302 w/ AFR Heads 3.73 Rear, Coil-Overs
Dave,
You may not want to put cripples in your shocks. I tried it, and bent the stuffing out of the rod at the lower a-arm after a bump. There is no good way to limit the movement without setting up a dangerous and possibly damaging situation. It really requires that the tire can move within the wheel well. Bumpsteer I can deal with, wrecked a-arms, fiberglass, a-arm connection points etc. I cannot.
Hope this helps.
Darren
