Old 03-12-2005, 07:32 AM
TonyMadrid's Avatar
TonyMadrid TonyMadrid is offline
Cobra Make, Engine: A&C 351W, C4
Default Options
If you're not running a heater, you can just plug it. What I did was I used it for a burp valve. I used a small brass pipe with an elbow and a drain cock fitting. When I fill the system with coolant, I fill it until coolant comes out of the drain valve thus removing all the air from the system.
Attached is a picture of the setup.
Burp Valve
