Old 03-13-2005, 07:34 AM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
You have already got some great advise and thought a link to reg. setting or specs might help. http://www.holley.com/HiOctn/TechSer.../FMFPTech.html
Check the pressure of the pump output for your application. If needle seat are good then must be a high pressure issue. 4 psi street to about 7 psi hot rod is a good to from range but read the link to holley
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
