Old 03-14-2005, 07:12 AM
Bruce Edwards's Avatar
Bruce Edwards Bruce Edwards is offline
Cobra Make, Engine: Hunter with a 4.6 supercharged
Is the gasket you are using a fiber gasket? Should have plastic rings in the corners to stop from over tighting the mounting nuts.
As far as the line you are using it will transfer heat faster than braided line however the factory used steel on the pressure side and it does not cause a problem.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
