Old 03-14-2005, 08:03 AM
Ron Going's Avatar
Ron Going Ron Going is offline
Cobra Make, Engine: ERA FIA 2095, 331, w/ TKO 500
I've been reading all of your post about brake squeal. I have an ERA and had the same front brake squeal. I tried silicone and other anti-squeal goop from auto supply stores.....nothing worked. I have the big wilwood front brakes on my ERA 289 FIA. I called wilwood and ordered a set of shims made for my brakes. My part number was 300-8460 and a set of 4 cost about $13 plus shipping. Once installed between the pad and the pistons the noise was gone. CALL WILWOOD! The only problem that I had was because my brakes were new, the extra thickness with the shim made for a tight fit. But it's doable. Good luck.
