Old 03-14-2005, 11:26 AM
bfleming bfleming is offline
Cobra Make, Engine: dual paxton 427 Cam Am Cobra
If you don't mind paying a little bit more, give Motorsports International out of El Cajon Ca. a call. They produce/resell a reproduction original style (i.e. authentic look) steel scatershield. The only issue is if you use a centerforce II clutch assembly you will have to grind off a high spot around the opening for the clutch fork.
