Old 03-16-2005, 02:48 AM
Hotfingrs's Avatar
Hotfingrs Hotfingrs is offline
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
First I'd check out this forum for parts.... http://www.corvetteforum.com/ Look in the C-4 section and also you could put a post for parts wanted. I ordered a new rear spring from EM and it was made by Vette Brakes, I found it too soft for my liking, even with the ride height adjusted full up position. Kept hitting the inside body under hard acceleration. I had a composite spring from Vette Brakes for a C-3 sitting around, the highest spring rate they made, I believe around 550#. Put that in and solved my problem.
Jack
XSSIVE .....
