03-17-2005, 10:56 PM
Ca
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Thanks Michael....I'd planned on pulling it tomorrow. The long block was built by a reputable builder back East....I never expected to run into this kind of problem. I don't mind pulling it as long as there is enough room to adjust slightly. It's almost as if the pump or the pump mount is machined at a slight angle instead of being perfectly horizontal to the engine. If I can't reposition it I might try a new pump to see if it's any better. If not I guess I can always machine the pump base slightly. Just another hassle I didn't plan on. Has anyone else ever had this problem?
