Old 03-17-2005, 11:12 PM
fxbill's Avatar
fxbill fxbill is offline
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
I'm not so sure the rod is bent...If so I do have an Arp standing by as well as another high volume pump from the 393 that went South when it dropped a valve. I'm more afraid the rod is fine, but the pump alignment or mounting angle is somehow wrong. I sure hope you're right though and it's just a bent rod.
