03-19-2005, 11:08 PM
Ca
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
I completely agree with Jack. A warmed up 302 will give you 350HP..and although it'll be a nice engine a 351 with decent heads, cam and carb setup will easily break the 400 horse mark...with a lot more torque than the 302 will give you....and more torque with your HP is where it's at!
