Thread: Too Rich????
Old 03-22-2005, 02:57 PM
ridelikehell ridelikehell is offline
Cobra Make, Engine: BRM #20, Ford 302, Holley 600dp
Send a message via ICQ to ridelikehell
thanks so far guys!
Steve I forgot to mention i'm running a full MSD ingition; 8582 Distributor, 6AL Box and a Blaster II coil...
I had actually thought before that I might have a vacuum issue because I was having quite a problem getting the timing/idle set right a little while ago...For a time I couldn't get it to idle with anything less than 18degrees base timing; but after many hours of tinkering with the idle settings I got it down to a 14degree base; could this possibly be causing the problem?
