Old 03-22-2005, 05:01 PM
FeWedge FeWedge is offline
Cobra Make, Engine: Kirkham 496 Aluminum Tunnel Port 687 hp 653 trq
What kind of problem are you having? The .750 master cylinder with .820 clutch slave cylinder should give you at lest 1 inch of travel. Make sure the clevis yoke is attached to the correct pivot point on the clutch pedal. I just went through this with my Kirkham. 3 weeks of hell trying to get some pedal pressure and 45 minutes to fix it when I figured it out.
Rob
