Old 03-23-2005, 08:23 AM
The Dreamer The Dreamer is offline
Cobra Make, Engine: KMP329 w/KC489 Shelby
Thanks for the suggestions guys. This is exactly what I needed. Now, I need to make some choices.
TC, that AP Racing may be the way to go. Which master did you use, the compact flange (CP2623) or the flange (CP6093)? Did you use the push rod from the Wilwood master? Was there anything else that needed to be adapted?
Cranky, of course they would only offer the wrong version of the size I needed. I thought that was typical of my luck. Plus, the mounting is different.
Rob, I'm pretty sure I'm getting full stroke out of the slave. The problem is a mismatch between the bore. The ratio is not in my favor.
Mike, thanks for the source. I have been looking at the CNC as well as their master.
Warrior, I'm considering re-sleeving the slave. The problem is I will be down for about 2wks
