Old 03-24-2005, 04:11 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
CM,
I tried the e-mail this time. If the notes mention timing he most likely retarded it some for the testing. The plug gap I would guess that he put in new plugs and maybe widened the gap a little to get a longer spark. If you are running an aftermarket ignition like MSD or Jacobs, you should run wider gaps than stock anyway. Not sure about the new MSD units, but with my Jacobs Pro Street I have played with gaps and the stock .035 didn't work well at all. I finally settled on a loose .049 and that seems to be the best for mine. Read all of the notes and then post anything that you have questions about. Some of these guys will be able to answer them.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
