Old 03-27-2005, 11:21 AM
Bruce Edwards's Avatar
Bruce Edwards Bruce Edwards is offline
Cobra Make, Engine: Hunter with a 4.6 supercharged
A tight valve may not show up with out a vac reading until you burn it.
It never hurts to check. If you only have one cylinder at this point that is that far off from the others I would check it just to be sure. It only takes a few moments and can save a valve job down the road. Even no solids need to be adjusted correctly.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
