  #22 (permalink)
Old 03-29-2005, 08:57 PM
Turk's Avatar
Turk Turk is offline
Cobra Make, Engine: What Cobra?
Send a message via Yahoo to Turk
David,
Don't bother. If you are going to install the latest (generation 11?) parts to make the car weigh less than the CSX 4308, I think you probably CAN do that.
The discussion wasn't if you could shave 300 lbs,with the latest and the best. The discussion was whether a CSX4000 car weighed 300 lbs. more. That's all.
Your references BECAME the original car somewhere into your argument. If you mispoke that is OK.
I have no problem with your assertion that KMP weighs less than a comparable CSX3000. It probably does. That proves nothing.. I would not have argued that. I think if you read what you wrote you would see that you were clearly arguing the weight differences with the CSX4000 and your car. Not alloy bits, not aluminum suspensions, just your typical run of the mill KMP and a run of the mill CSX.. I say they weigh the same.
If you were comparing the KMP to CSX3000, why are you weghing the CSX4308?
We didn't get any further this time than we did the last time we mixed it up. I stand by everything I said, and would be glad to drop it and move on. Feeling will not change anytime soon. No sense of providing cheap entertainmemt for other members.
OBAMA IN in 2012
