Thread: Clutch Setup
Old 03-30-2005, 12:24 PM
cwmcobra's Avatar
cwmcobra cwmcobra is offline
Default Clutch Setup
I've got a 514 with Richmond Gear Street 5-Speed. I'm using a Ford Racing flywheel, Centerforce clutch and McLeod hydraulic throwout bearing in a Lakewood bellhousing. The bearing has failed twice and I want to replace it with another brand. I've talked with Tilton and they claim their bearing won't work with this combination because the Lakewood bellhousing is shallow and the Centerforce clutch is tall.....the bearing won't fit. That means I either fix my setup and try it one more time or I find another clutch that will work with the Tilton bearing. What combinations are you running successfully inside a Lakewood bellhousing?
Thanks!
Chuck
