  #58 (permalink)
Old 03-30-2005, 07:07 PM
Alex Evonosky Alex Evonosky is offline
Cobra Make, Engine: Building from scratch
Default Bob Some Info.
Bob,
First thing, drawings are from:
Cobra Restorers
3099 Carter Dr.
Kennesaw Ga.
30144
Try www.cobrarestorers.com or google. I can't find the information at the moment.
Ph. 770-427-0020 (I believe his name is Chuck)
I believe he has drawings or CD.
Then check out Pole Position for suspension parts such as upper and lower control arms. I used the modified MII adjustable uppers
and MII lowers. The lowers come with the cross shaft but I took it appart and machined steel bushings so I could have independent pick up points.
Web page www.polepositionrp.com
Phone # toll free 888-303-8555 Ask for Ted. Tell him Alex said that he would help in answering your questions.
Then the rack and pinion is from Flaming River in Ohio www.flamingriver.com
All my frame and brackets are home made.
Also, If you are planning on building and using the original parts, Cobra Restorers can help you with that also.
Don't get confused, as I am building a cobra to race and go not shine and show.
I will be posting some pictures probably next week. I have been pretty busy and going to Bristol this weekend.
Cobracer
